Ga door naar hoofdinhoud
The Samsung Galaxy A33 5G Is a Mid-Tier phone released by Samsung on April 20th, 2022.
speaker not working properly?
Low and muffled sound coming from the speaker
Is dit een goede vraag?
Score 1
1 Opmerking:
Speaker not working
A33 samsung
door
Voeg een opmerking toe
2 Antwoorden
Hi Mehmet,
If you look at the bottom of your phone, you should see a speaker grill.
Is it clogged? if there is dust or other debris blocking the grill it will lower your speaker's performance.
Let me know what you see, and we can take it from there :)
Was dit antwoord nuttig?
Dust is there
1 Opmerking:
Use something like a pair of small tweezers or a needle to gently clean out the charging port. Please be careful of the metal contacts on either side of the plastic piece in the middle of the port. Scratching or otherwise damaging these could result in a loss of charging functionality
door
Voeg je antwoord toe
Mehmet Buğra Avcı zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 171
