Ga door naar hoofdinhoud
Wi-Fi-only versie van de 2e generatie iPad Air van Apple. Model A1566.
iPad Battery drain fast
Hello everyone, this is y mom's iPad (Device model iPad Air 2 16GB) and since the last week she's been experiencing some battery performance issues, basically it drains very fast even when is not used. I already turned off the background refresh to see if it helps but made no difference, then restore and updated the iPad with the software version 15.8.1 (it was already in the last iPadOS version when restored) and yet no difference once again. I checked using coconutBattery and shows 86% battery health. I had a similar issue with my iPad (9th Generation) a time ago, and was fixed just by turning off background refresh, so I thought it would help this one too. There is the picture of the battery draining by itself, and the iPad is completely clean, no Apps, no Apple ID, no files, nothing but the default apps.
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The battery health percentage isn't always the best way of determining if the battery needs to be replaced. Even though it says the battery is at 86% health, it still needs replacing.
Follow this guide:
iPad Air 2 Wi-Fi Vervanging van de batterij
iPad Air 2 Battery
Replace a 7340 mAh battery compatible with iPad Air 2 A1566 and A1567 model tablets. Part #020-8558. 3.76 Volts (V). Battery model A1547. Afbeelding
Product
iPad Air 2 Battery
$49.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Alejandro PeƱafiel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 1,257
