Ga door naar hoofdinhoud
Repair guides and support for the C650 series of Satellite laptops by Toshiba.
33 Vragen Bekijk alle
Why my PC has ceased recognizing any flash drives plug in
The problem is that the PC has ceased recognizing any flash drives plugged in, and I am not sure why. Could there be any wiring issue involved, and is there something that could be done about it
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Good afternoon,
I'm assuming as this is a toshiba. That you are using a windows operating system, if you are on the off chance on Linux please let me know.
Dependant on the operating system there are a few ways to diagnose this issue.
I'd like you first to start by removing the flash drive and then press the "windows" key on your keyboard and type In disk management
Once this page is loaded, keep track of how many disks are listed (starting with disk 0)
With the page loaded plug back in the flash drive, do you see any new disks listed?
If so what do you see? If these disks previously had no data on them(or data you aren't afraid to lose) and the newly added disk states "waiting Inialization" go ahead and initialize it, you should then be able to use that flash drive like new.
I will eagerly wait your respond to continue assisting you.
Was dit antwoord nuttig?
Voeg je antwoord toe
Meklit Seboka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 36
