Ga door naar hoofdinhoud
Repair guides and documentation for the Google Pixel 5 smartphone. Released October 15th, 2020. Model Number: GD1YQ, GTT9Q
Pixel 5 antena replacement alternatives
My Pixel 5 detects my sim, but no signal at all on both my physical and esim after a minor water damage. WiFi works, I just can use the sim because it shows no signal at all. After some research I suspect the antenna is damaged, are there any alternate antennas that I can replace it with?
Is dit een goede vraag?
4 opmerkingen:
I just can't* use the sim because it shows no signal at all
door
@russellpeiris
Have you fixed the water damage?
door
Yes, the water was removed, and some components in the charging area was cleaned, it seems the antennas are not damaged, the technician suggested it might be an issue powering the signal, I'll be handing over the phone to him for further inspection (inspecting the ic and stuff)
door
same story here after water damage , mine also don't wanna open cameras anymore ,modem is probably most sensitive and most exposed on the board
door
Voeg een opmerking toe
1 Antwoord
Hi @russellpeiris
It seems the answer is your antenna is not powered due to water interference/damage
you should replace the cable to the antenna
let me know of any further developments
Was dit antwoord nuttig?
Voeg je antwoord toe
Russell Peiris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 318
