Ga door naar hoofdinhoud
Reparatiehandleidingen voor rolstoelen.
Invacare Motion 9000sl wheelchair - wheels rubbing against chair
The wheels of my secondhand wheelchair are rubbing against the side of the chair. Has anyone experienced a similar issue? How might one go about fixing it? I am new to this chair.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
In my limited experience, hardware on the chairs seems to work loose with time and use. Have you tried taking a wrench of appropriate size to every fastener on the chair to be sure they are tight?
Was dit antwoord nuttig?
I created a page for your model of chair and added the user manual to it. Invacare 9000 Series Wheelchair
Your chair might have spacers on the axle, so you probably need to make sure those are present. (user manual page 55)
It looks like there isn't much adjustability offered in the sleeve, or at least there is not instructions in the user manual. You want to make sure it is identical on each side.
You also should make sure the parts have not loosened, which could make one wheel unsteady. And make sure the quick release axle is fully inserted when the wheel is attached, so that it can not shift out.
There are other wheelchairs with manuals that explain tightening the axle area in more detail, but they might not fully apply to your chair.
Here is a quote from Quickie on page 19 that describes how to make sure the axle pins are tight enough. The manual also has drawings describing the parts more clearly. (https://www.sunrisedice.com/asset-bank/a...)
Voeg je antwoord toe
Emilynn Jay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 466
