Ga door naar hoofdinhoud
De iPhone 13 mini werd uitgebracht op 24 september 2021 en is een kleinere versie van Apple's iPhone 13 en de tweede mini iPhone. Het toestel beschikt over een 5,4-inch OLED, een A15 Bionic-processor en twee camera's achteraan.
LCD came off its bracket?
Afbeelding
[Help] Did screen pop off screen frame?
Hello, I am replacing battery on iP 13 mini and looks like lcd screen came apart from screen frame. I have never seen or heard about it before, does anyone know how to proceed here? I am worries about face id sensors since the top part wont come loose when I try to separate it.
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Generally when we've seen this issue on an iPhone, it's been because the person forgot to take out the pentalobe screws first; otherwise the glue Apple uses seems to do a good job holding the parts together, so if you haven't removed them yet, that's the very next thing to do before going any further.
I agree with your diagnosis that it appears the LCD is coming off its frame. At this point you've got two options to continue; you can go ahead and proceed with taking the LCD off first, then go back around and remove the frame. If you do this the front sensors will stay on the phone rather than coming off with the screen like normal.
The second way to do it is to go back to the bottom of the phone and insert an opening tool between the screen frame and the phone frame and separate it, then continue on around getting the frame up. Once you've gone all the way around then you can hold the screen and frame together and take them off as one part.
Either way should work, although I would lean toward the second method in hopes it will be a little safer in terms of avoiding damage to the sensors. Whichever one you choose, you'll obviously have to purchase some glue to reglue the frame back onto the screen so you can reassemble it once you're done.
With care you should be able to get it apart without damage, so take your time and use a blow dryer or heat gun to soften the adhesive on the frame as you remove it.
Update (02/16/25)
@stephanandersen I haven't done a lot of work on newer iPhones, but on ones like the X when the frame separated it usually happened on aftermarket screens for me. That's not to say it can't happen on an original screen, just that when we see it, it's usually from not removing the screws, but as you've found, not always.
As described in my original answer, you'll want to go ahead and disconnect the LCD to get that out of the way, then get the screen frame separated from the phone's midframe. If you use something very thin you may be able to pry it up from the outside, but you could also go in from the inside with, for instance a thin flat blade screwdriver and twist it carefully to get the adhesive separation started. Once you've got a gap, go around with the opening picks just like you would with the screen still in place.
The sensors will come off and at that point you can unplug them. If you're planning on reusing the screen you'll obviously have to glue the frame back on, so you'll want to be careful when removing it to keep from bending or warping it as much as possible so it'll go back on securely.
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
I had exactly the same issue. The LCD came off the frame even though I took out the pentalobe screws first. Now the frame is stuck to the phone and the sensors has separated from the lcd? What do I need to do from here?
door
Hello! I was wondering what glue you should use in a situation like this to glue the screen and screen frame back together? And should I attempt to carefully remove the screen from the screen frame and then reglue them together in my case where I accidentally had opened a small gap between them both at the bottom of the phone when trying to detach the whole screen from the back of the phone? I also noticed the glue between the screen and screen frame/bezel is peeling a little along the edges, i'm nervous about this being a moisture issue in the future.
door
@dadibrokeit
I had accidentally wedged just a little into where they tell you on step 9 not to (between the display panel and bezel) iPhone 13 Vervanging van het scherm
I didn't even know you could separate the two because my situation was a battery replacement and I hadn't seen anybody talk about this issue up until searching hard for it because something about it felt wrong when I was trying to get the whole screen off lol. I also think, like step 9 says can happen, that my display panel already lifted when I used the suction cup thing before I attempted to wedge anything in there. I'm really trying to avoid having to replace the whole screen, but I also don't want to have moisture issues because of the already open small gap and the weak seeming and peeling glue
door
@dadibrokeit
My apologies, I didn’t realize I could have tagged you when I sent the first message. Please read that one first when you have the time, it’s still in this comment chain
door
@anyjay First, if you can get under the screen frame and get it and the display off in one piece, that's definitely the way to do it. I was in the same situation on an older phone and decided to just go ahead and separate the screen from its frame then take the frame off afterwards. Didn't work out so well; I ended up damaging the OLED, so yeah, get them off as intact as you can and don't try to separate them afterwards either.
I'm not sure exactly what glue to suggest; normally I call for B7000, but that's more for screens and backs and it's assumed you're going to want to separate it again at some point, so I'm thinking you'd want something more permanent, perhaps some sort of epoxy. You might have to do some homework on that one; I'm afraid I'm not an expert in that department.
door
1 commentaar meer tonen
Hi,
If you want to repair the battery, the screen must be removed to access the FPC and flex connector. As long as the screen is not damaged and the front camera is not damaged or dirtied, the Face ID will still work,
If the LCD has detached from the screen frame, this is a different issue.
I have the same issue. The LCD has separated from the frame which is still stuck on the phone. This happened even though I carefully removed the pentalobe screws first. This means that the sensors are separated from the LCD and are now stuck to the phone. What do I do from here?
Voeg je antwoord toe
jakeemsnakeem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 108
Altijd: 2,218
