Head phone swivel broken; want to repair it
Swivel point at headphone end of extension is broken.
Afbeelding
Afbeelding
It appears that the broken part is two pieces. It also appears that if I had a replacement part that I could remove two screws to remove the old part. However the male portion of the swivel appears to fit into the earpiece 'fork' behind a rectangular plastic door that likely must be pried out. I assume there is a form of washer or split washer that holds the swivel male portion into place. Any idea if Cowin still supports these with parts?
Is dit een goede vraag?
Voeg een opmerking toe
