Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Can I swap the motherboard from a newer MacBook?
After almost 13 years of faithful service, my 2011 MacBook Air finally died. All the repair stores said that nothing short of replacing the motherboard would help and they wouldn’t do it, so I decided to do it myself. I was wondering if it could be replaced with a board from a newer Marbook Air? From air 2017, ideally. The body seems to be the same, the motherboard looks identical.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Check out this thread. The short answer is that logic board from the 2013 through 2017 models are interchangeable, but the 2012 and earlier models are different, so a 2013+ logic board cannot be properly installed in a 2011 MBA.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
[deleted] zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 313
