Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac beeping 3 times and has a blank screen
Hi there,
I have just started up my iMac and it keeps booting with 3 small beeps, 3 long beeps then 3 small beeps. I have been on the phone to apple and they are no help. This just keeps on looping and I have taken out the RAM and reinserted. I would appreciate it if I could get some help on this.
TIA
Taza
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@taza Here are a couple things you could try:
  1. Try removing the RAM completely from the iMac
    • Does it still give you the same sequence? If so, then try each RAM module one by one to check if it works or not. Maybe one of them doesn't work which would cause the iMac to beep.
    • It's also possible if someone placed the RAM into the slot in the wrong way and damaged a slot, so try the other slots if you suspect one of them doesn't work.
  2. Try SMC reset
    • Unplug the power cord, wait 15 seconds, attach the power cord, wait 5 seconds, then power on.
    • It may not work but it has helped for some people
  3. If you see a loading bar, then the iMac is probably updating its firmware, which could take a while
I hope this helps :)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Taza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 83
