How do I fix Lines on Screen
They flicker and appear and disappear often. I bought used. There is no damage on the outside of the case or inside. Could this be a loose cable or something?
Is dit een goede vraag?
Sadly your display is damaged. Did you bang the hinge edge, crack the chin plate which is just under screen area which can puncture the ribbon cable just behind it. Lastly, don’t use a hard shell or camera blocker (use black tape if you must)
The only solution is replacing the display assembly MacBook Pro 14" (2021 A2442) Display Assembly and here’s the guide MacBook Pro 14" 2021 Vervanging van het scherm
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 30
