Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
Shutting down while plugged into power supply
Hi. I just got my iPhone XS Max and whenever I plugged it into power supply it charges for some seconds and the next thing me checking it back it’s at switched off. That means it’s automatically switches off itself.
If I then unplugged the charger it will then power on it self. Then when power on itself I later plug it into power supply and continue using it while charging and no problem but if I just drop the phone down for it to charge it will still power off it self again.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The main problem that you faced is while not keypad is locked you can use it for a long time but when you leave the iPhone for something it shuts down. That is the issue that I faced and after hours of research, I found the solution there is a problem with the circuit that helped me in that case you can also try once.
Was dit antwoord nuttig?
1 Opmerking:
did u changed the circuit? plz help me im facing this issue
door
Voeg je antwoord toe
Sirojuððin Salau zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 131
