Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Why does the diagnostic LED1 turn on after hours?
I've been troubleshooting an old iMac 2011 27". After removing the screen I could use the diagnostic LEDS to gain some info.
When LED1 is on, the machine can be booted without problems. After disconnecting/reconnecting power this LED stays off. It can take hours till LED1 turns back on. After that it boots without a problem.
Am i correct to suspect a bad PSU for this behaviour? I just want to make sure before ordering a piece worth more than the Mac :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would double check the AC power, a bad ground can send you down the wrong path. Get a simple outlet checker and also check the cord by trying a second cord and check the system socket.
Was dit antwoord nuttig?
Voeg je antwoord toe
DieterL zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 47
