Ga door naar hoofdinhoud
The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Vragen Bekijk alle
Run windows on a power mac G4
Hey, can i run windows on a Power Mac G4?
Which parts do i had to replace?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
No and yes. You can't run windows on a Power PC Mac. There's some Virtual PC software from ages back that emulates the x86 processor architecture necessary, but it never really worked well. I have it and I'll give it away, but it's not worth the effort. The newer versions require a minimum 1 GHz processor, anyway. http://en.wikipedia.org/wiki/Windows_Vir...
Was dit antwoord nuttig?
Score 3
8 opmerkingen:
You neglected to mention the possibility of a multi-boot, it doesn't have to be virtualization.
door
rab: you can't boot a g4 into windows. This is emulation, not virtualization, anyway.
door
Virtual PC 7 (I think the last version, company was purchased by m$) did run on PPC machine, however it was win95/ME/XP. It ran stable, but there were some things (particularly games) that didn't run or the hardware peripherals wouldn't be recognized.
Maybe you could find it online (ebay or Craigslist)
N .
door
rab if you're going to use this as a reference, how about negating the downvote you gave me on it ;-)
door
I did, someone else must have downvoted it
door
3 commentaren meer tonen
Thanks for the help!
I don't think I will do it, because i had to upgrade the processor then!
You can use software like Paralells to run windows inside mac OS, but windows cannot natively run on a mac, however they can run versions of linux.
Score -1
5 opmerkingen:
-1 Parallels doesn't work on ppc.
door
Oh, i know there is a program for that, but i misused the name, i'll try and find it.
door
WinTel $30 @ http://www.openosx.com/wintel/
Does it work? Do not know...
door
No, only for Intels
door
Voeg je antwoord toe
lukaslevin143 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 5,811
