Why is my screen not turning on?
Screen not turning on after its connectors disconnected after it fell and the tech repair dude forgot the screws for the outside,the glue,the sticker and there is a pressure on the home button,so it doesn’t work and it puts pressure on the screen.
Is dit een goede vraag?
I could use some clarification here on the order of events. Let me see if I understand.
The screen doesn't turn on because the device was dropped. You attempted to have it repaired, but it's still not working and the person who did the repair did not reassemble the device as completely as it could have been (some steps were not done).
Also the home button isn't working due to pressure on it, further causing pressure on the screen.
I presume the screen was replaced? Or is this the same screen that was the original issue?
Explain a bit more what you mean about the home button. There's pressure on it? From where? How can you tell?
door Alisha C
