A2019, Mac pro, new battery, no charge
MacBook pro a2019 15"
Started not charging, took it in he disconnected battery said it was fine. Got home wouldn't turn on reset SMC, use the different port thought problem fixed or needed a new battery. Restarted recently and it would not start.
Ordered and replaced battery, everything turns on fine I am now at 45%, will not charge, port works as I plugged in external device, can't update due to battery life. Power cord good, one that came with computer and tested with other devices.
When I plug into one of the ports the machine will automatically start, strange and never happened until recently.
Did not see anything loose during battery install.
Touch bar also has not worked since this all started, it shows power takes no commands. Not worried about that.
Changed battery optimization settings in case there was an issue, no change.
Is dit een goede vraag?
Sorry I don’t know of a A2019 system could you met this instead MacBook Pro 15" Touch Bar 2019
door Dan
Changed it. But have not been able to find anything helpful yet.
door Lee Clayton
