On/Off switch repair- seems simple?
Hopefully someone can tell me the pins I can solder into to essentially wire-in my own on/off switch.
On the circuit board I can solder on some thin gauge wires to the old switch lugs/pins and the on the other side of the wire attach a on/of switch. The factory switch came apart and one of the little brass(?) pieces was lost.
What would you suggest? I don’t l know which points to jump.
Probably super easy for someone to figure out
Is dit een goede vraag?
@zacharialow Do you have a multimeter so we can check some voltages?
door Andrew S
