Ga door naar hoofdinhoud
Released November 9th, GoPro's Mini version of the 2022 flagship camera HERO11 Black features a 27.6MP sensor and GoPro's GP2 processor for video resolutions of up to 5.3K 60fps with 10-bit colors and onboard HyperSmooth stabilization.
Can the lens be replaced?
Is the lens screw on m12 and can it be removed and replaced as you could with older models?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
On the GoPro 10, 11, and 12 models, the lens can easily come off as you rotate the cover, and then the screws are visable.
Hope you find this helpful!
Was dit antwoord nuttig?
2 opmerkingen:
Does this mean that you can just unscrew the lens from the assembly?
The m12, and the flange being the only issue left?
door
Yes. You will be able to unscrew the four screws after rotating the lens cap off.
door
Voeg je antwoord toe
k1tk4 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 264
