Ga door naar hoofdinhoud
Can't regulate heat
Cannot regulate the heat
Update (11/23/23)
Whirlpool Model ACE244XSO The heat will vary 10+ degrees------ up and down without moving the thermostat setting. Probably the thermostat but I haven't found one for it.
Is dit een goede vraag?
1 Opmerking
Hi @calvinwiles,
What is the make and model number of the Air Con unit?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @calvinwiles
There are two thermostats in the air con unit, Item #10 and #31 airflow and control parts diagram
Temperature control thermostat Item #10 is part # WP1185753 (supplier examples only).
Item #31 is part # 4388458 but I can't find any online. This one looks more like a safety cutout thermostat for the heater given its location, rather than a room temp control thermostat like Item #10. If you suspect it is the problem, check if there's a different part number on it or a make and model number and search online using that information
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Calvin Wiles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 112
