Ga door naar hoofdinhoud
Repair and disassembly information for Sony WH-1000XM4 wireless noise-cancelling over-ear headphones.
No sound from the left side.
Hello, I bought Sony WH-1000XM4 headphones in unknown condition. It turned out that the right side, the speaker and the touch panel were fully functional. On the left side, the buttons, NFC and indicator light work. The only biggest problem is that there's no sound from the left speaker. I tried to connect to the computer via aux and again, sound could only be heard from the right side. What could be causing this problem? I would be very grateful for your answer.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hi,
I've had the same thing happen to my headphones. What I did was I wiggled the left earpiece around until the right sound turned on; It would only turn on if it was placed in a specific way so every time I use them i need to wiggle it. If you want to fix it permanently, you could try opening the left ear cup and checking if anything is disconnected, because that is usually the problem. Hope I helped!
Was dit antwoord nuttig?
2 opmerkingen:
I opened it and checked if anything is disconnected before that and no, everything seems to be alright.
door
Im not sure then. Sorry.
door
try diffrent songs or sound tracks and see if there is a change.
Voeg je antwoord toe
thezoneofcum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 118
Altijd: 1,488
