Ga door naar hoofdinhoud
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Vragen Bekijk alle
Vraag afgerond
Is it possible to change/upgrade my Graphic Card on my PC?
Is it possible to change the graphic card on my SATTELITE L750-1T9, I'ts an Intel HD Graphics 3000.
Also will my warranty void if I open the PC??
Is dit een goede vraag?
1 Opmerking
The Intel HD Graphics 3000 services is embedded into the CPU chip. Review this Integrated graphics card in the Sandy Bridge codenamed processors
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
nope, because its embedded to your logic board
Was dit antwoord nuttig?
Score 1
2nd question: If you have a still alive, good warranty... Yes you would void it.
1st question:I agree with "Wakitech", BUT...I would suggest getting an EXTERNAL [ and connect it to the external video in back of laptop] computer monitor & download the latest software for such], because I suspect you want to play GAMES [ or gaming computer ??!!]
Technically yes, But that would involve unsoldering the current chip, and adding a new chip by reballing it on, which if you dont have the tools is literally impossible. I have the tools to do it at my shop (We do PC and game console repairs) and I still have only seen it done successfully 4 or 5 times
1 Opmerking:
The Intel Graphics 3000 is embedded into the CPU not a stand alone GPU. You would need to replace the CPU and then you have the issues of what to use instead of and if the system could even support it. Bottom line here not replaceable.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,299
