Ga door naar hoofdinhoud
Model A1224 / medio 2007 en begin 2008 / 2, 2,4 of 2,66 GHz Core 2 Duo-processor
Can you help with the folder with question mark logo?
Hi, I am getting a folder with a question mark in it. I turned on my iMac after a long time. It started up but it froze on Home Screen with wifi option on.
I couldn’t click or press any buttons so I did a hard reset by pressing the power button and after that I started getting that logo with a folder and question mark in it.
Only thing that works is if I hold down the alt/option key are startup but it only shows a mouse cursor.
Help. I do not want to lose my data on it and also I don’t know what operating system it’s running on and don’t have a backup.
I have another iMac that was connected to it via Ethernet cable long time ago. I have also heard of an option by running it through FireWire with the other iMac but I don’t have FireWire cable and don’t know if that would work or not
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Sadly this sounds like your hard drive is probably on its last legs. That’s not unusual for a device of this age. Folder with a Question mark typically means the Operating system cannot be found. Which is usually caused by a corrupted OS or a failing drive.
It sounds like you mostly want to get data off of this computer? What happens if you try and utilize target idk mode. Press and hold the T key on the keyboard right after you press the power button. Does it go into a different moe? It will likely have a Thunderbolt picture onscreen.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Barabaapu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 285
