Ga door naar hoofdinhoud
Apple's nieuwe format voor de 14 lineup bevat een 6.7-inch OLED-scherm—zoals de Pro Max—maar ook dezelfde features als de iPhone 14, met een dubbele camera-setup en de Bionic A15 chip met een 5-core GPU.
20 Vragen Bekijk alle
Extra part after disassembly, please help!
Hi guys,
I've taken apart my Iphone 14 Plus to put everything in a new housing. unfortunately in the process I've taken something out which I now don't know where belongs. Can anybody please help?
Thanks a lot!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Thanks for the input @flannelist. Some very close inspection of teardowns helped me to find the location. It's something between the speaker and the charging port part. I've attached a picture below. Phone all working now! Thanks!
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
I have not worked on one of these yet. But Apple loves little bits like these. It looks like an antenna of some kind. Based on the way its shape I would wager it goes into the side of the housing somewhere, like a button flex. My first through would be the NFC antenna which is usually in the sidewall of the housing near the rear camera. But I haven’t been able to pin down the location for sure.
Here’s a pretty in depth teardown for the 14 Plus on a top down view. You might be able to find the placement based on this.
https://youtu.be/QlkC6_AiinU?si=9s53xDZB...
Score 2
Voeg je antwoord toe
Michael Buijs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 114
