Ga door naar hoofdinhoud
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
Charging pogo pinout - diy replacement of dock
I want to make myself a charging dock out of the box the headset came in but I'd need to know the pinout and possible handshake I would need to mimic. Could anyone who has the dock measure the voltages and see/record and communication over the data pin?
Is dit een goede vraag?
Score 7
4 opmerkingen
i want to know the same thing as well, i already use a magnetic usb c cable but a dock would be nicer
door
Me too please. Can someone take a meter to one of these docks a tell us what the pinout is?
door
Just waiting for someone... anyone, to buy the dock 😆
door
Hi.
Did you ever make one? if so did you 3d print it, and can you share the files?
and the schematic.
thank you
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
靠近中间的PIN是GND,靠近外部的PIN是+5V,中间的PIN通过改变对地阻值反应充电状态。我使用这个定义并完成了电路部分的demo设计。可惜的是我不擅长结构建模。
更新 (12/29/23)
like this
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
只要你保证电压是5v,就不用担心简单的反接测试会烧毁设备,因为我已经试过了lol
door
I don't know Chinese, please let me know if you'd prefer me to use some translator.
The inner pin doesn't matter in this case? It's enough to provide 5V to the outside pin and ground to the middle one? I tried doing this with some USB charger cables without luck back when I posted the question.
door
The PIN near the middle is GND, and the PIN near the outside is+5V. The PIN in the middle reflects the charging state by changing the ground resistor value.
use a 10k pull up resistor link to the pin in the middle pin. 5v means NO CHARGING, 1.7 means CHARGING.
door
The inner pin just a indicator for charging state. if I am right.
door
https://www.meta.com/quest/accessories/q...
official accessory page says:
USB-C Input 9V/12V/15V
Contact Output 5V/9V/12V
so there seems it suppport charing at a higher voltage
door
Connect the wires, red to red and black to black and add a type A port to charge it
1 Opmerking:
Which wire to which pogo pin? :) Tried checking USB 2 connection like this without luck.
door
HI.
Did you ever make one? And if so, did you 3d print it and can you share the files. I think i have a schematic but could you share what you have?
Thank you
I think the same for the magnetic port. My homemade battery works
1 Opmerking:
Would be nice to figure out and open source the docked charging for the official Elite Strap with Battery, so we could benefit with any battery strap. Knowing Meta, that's probably somewhat locked down, needing the board from a sacrificial official strap.
door
Voeg je antwoord toe
Domi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 96
Altijd: 1,665
