Ga door naar hoofdinhoud
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 Vragen Bekijk alle
mz-jpu512t/0a6 enclosure
Hello,
will this item fit a samsung mz-jpu512t/0a6 ssd (from a 2013ish imac)?
External M.2 SSD NVMe Enclosure
I didn't see any way to ask this question on the product page.
I extricated the drive and ordered what I believed was the correct enclosure, but I was mistaken. Looking through enclosures here and on amazon, I cannot find any that will fit this ssd.
Any help--any!--would be appreciated.
Thanks!
Use an M.2 SSD as an external drive in this enclosure. USB 3.1 transfer speeds up to 10GB/s Afbeelding
Product
$19.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Is it the PCie based SSD? If it is, you should be able to buy an adapter. However, I do not believe that the product will out of box fit the SSD, and you will need an adapter.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Pat Foster zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 274
