Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
[SOLVED] How snug should the battery connector cable be?
Im afraid to break it if I push it too hard, but it still doesnt recognize it. How snug should it be? The little flap is already pushed up.
UPDATE:
It had to go deeper than that. It worked.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The ZIF ribbon connector requires very little insertion force into the slot. The cam latch likewise only needs a little lift pressure to unlatch and folding it down once’s the ribbon cable is inserted fully and squarely.
Looking at the image it appears the ribbon cable is fully and squarely inserted, but! The latch has not been folded down yet!
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
I edited the question so its clear which cable I mean, sorry.
The latch is still up, yes. So it doesnt go deeper than that? Unfortunately the battery is still not recognized... What could the problem be?
door
@vedsil - Let’s backup here… I’m assuming you replaced the battery, does the system even boot up when charger is plugged in? Do you have access to a USB-C power meter to even see if eve system is taking power. Have you tried a second charger and cable to be sure.
Lastly, did you carefully fold the latch down?
door
@Vedsil Dan is right that the cable is fully inserted but that the ZIF connector latch needs to be in the down position in order to fully connect the cable.
door
The latch is down, the system boots up normally, everything is working but the battery is not recognized at all :(
door
@vedsil - Let get a better view now that we have access. Download this gem of an App CoconutBattery it wii allow us to see deeper into your problem. Take a screen snapshot of the Apps main window and post it hear so we can see it too.
It’s starting to sound like a bad battery once we see the snapshot we will be able to tell.
door
3 commentaren meer tonen
Voeg je antwoord toe
Vedsil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 179
