Ga door naar hoofdinhoud
Kodak easyshare zd710 battery issue
So today I got a Kodak easyshare ZD710
and it's got a battery issue.
Everytime I insert new batteries the camera thinks the batteries are drained!
Has someone got an idea to fix this?
Update (10/01/23)
Update 1 :it sometimes happens when I insert/reinsert batteries
Update (10/01/23)
It's not from a store btw
Update (10/01/23)
It works but it might happen again when I reinsert batteries
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I've got a similar issue with my Z712IS. When it was new, I could change the battery and the camera would retain the clock for a minute or two while changing it.
Today, even if I rapidly swap the battery in 1-2 seconds, the camera will lose its time/date settings.
The official word is that this shouldn't happen - that the camera has capacitors that will retain the time for a short time while the battery is removed. If that's so, then the caps have died, but I have no clue how/if they can be replaced.
I think it is more likely that there is an internal battery (or maybe a supercap) designed to run the clock independent of the battery pack, and it needs to be replaced. But without access to any service manual to teardown document, I can't prove that.
Update: I found the teardown for the Z650, which shows what appears to be an internal battery: Kodak Easyshare z650 Teardown. So maybe there is one in a Z712IS or a Z710 as well.
Was dit antwoord nuttig?
If you just got to today, I would return it and get an exchange. Take your batteries with you and install them in the store to make sure they work.
1 Opmerking:
This would work out but it's not from a store or something
door
Voeg je antwoord toe
Pawel C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 285
