Ga door naar hoofdinhoud
The Samsung Galaxy A33 5G Is a Mid-Tier phone released by Samsung on April 20th, 2022.
Why my fingerprint sensoe is not working?
I got my phone repair but now its unable to read my fingerprint
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You could try redoing your fingerprint for touch ID.
Steps:
  • Open Settings.
  • Go to touch ID and passcode.
  • Enter in passcode.
  • Change passcode or setup alternative appearance.
  • Hope this helps.
Was dit antwoord nuttig?
Score 1
It sounds like you may need to have your fingerprint sesor calabrated. Go to your fingerprint settings and click on them if it says you fingerprint sensor calibration needed. then you will need to calabrate the sensor. This is common after screen replacements on Android phones with finger print sensors in the screen. Also if you are running Android 10 it pairs the screen and motherboard but the A33 is new enugh that it sould be running a newer version.
Score 1
1 Opmerking:
This is display issue , you put cheap display folder this is not support finger sensor i think so this is correct answer..?
door
Voeg je antwoord toe
Rohit Shinde zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 839
