Ga door naar hoofdinhoud
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
191 Vragen Bekijk alle
Will WD_Black SN850X SSD with heatsink fit into Mac Mini (late 2014)?
Hi all,
My Mac Mini stopped booting and now has a folder with question mark symbol on startup. Disk utility shows "APFS uninitiated", and reinstalling the OS doesn't work because the boot disk is not even showing up to choose it.
I also don't have a recent backup. So eventually, I've decided to just change the SSD and HDD and avoid the risk of formatting.
My question is, will the WD_Black SN850X SSD 1TB with heatsink fit into the Mac? I can't seem to find any info about whether the heatsink will make the SSD too large. And that too with the NVMe adapter if I'll need it.
I'd appreciate any and all info about this topic,
Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The SSD with heatsink might give you some issues due to the heatsink interfering with the clearance of the Antenna plate, but your core issue isn't the physical size of the SSD. Apple uses its own proprietary SSD which are keyed differently than other M.2 drives. You could probably get away with using the SSD without a heatsink and a Converter Card Upgrade, or if you don't want to bother with the upgrade iFixit does sell the OWC Aura Pro X2 SSD, which should give you a pretty decent upgrade over the stock SSD.
OWC Aura Pro X2 SSD Afbeelding
Product
OWC Aura Pro X2 SSD
$99.99
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Hey Jacob,
I really appreciate your answer! Thank you for the alternative as well.
Have a good day/evening ☺️
door
For Fusion Drive HDD replacement should I get this 1 TB 5400 RPM 2.5" Hard Drive
Or Crucial MX500 1 TB SSD
door
@xxrainkatxx Upgrade to the SSD. They're a bit more reliable than the standard HHD, and tend to fail a lot less often.
door
Voeg je antwoord toe
xxrain_katxx zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 71
