Ga door naar hoofdinhoud
Vraag afgerond
white screen, also on external monitor
My macbook gives only a white screen when starting up.
You can hear the chime, but the screen stays white.
Tried an external monitor, but does not work either.
I tried the following:
Resetting SMC
starting up with C, ALT, ... pressed
booting without HDD
booting with only 1 RAM memory strip
booting with a apple DVD,
All of them dont work.
any suggestions??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Bad VGC
or logic board. The unit may have been dropped or wet to damage the video graphics chip. Repairing/replacing a Video Chip on a laptop is not for DIYers... it requires advanced skills in electronics, soldering and soldering equipment.
If this answer was helpful please remember to return an mark it Accepted.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Reparing /replacing the chip will be no problem.
Do you think reflowing will be sufficient?
door
After replacing the VGC the board is OK.
Thanks for the replies !
door
Rene - you're welcome, glad to have helped.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 770
