Ga door naar hoofdinhoud
The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
Why does my paper get jammed when printing
So whenever I print anything the paper get jammed any idea how to fix it
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Paper getting jammed repeatedly is typically an issue with incorrect alignment, some obstruction in the paper's path, or an issue with the paper feed mechanism. Anything that can introduce a wrinkle. or a fold to the sheet of paper could produce a jam.
I would make sure everything in the path of the paper is clean and, inspect parts for signs of wear, be especially mindful of wherever the jam is happening (assuming it's usually in the same place).
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ABDUL RAHMAN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 190
