Ga door naar hoofdinhoud
The Motorola Atrix 4G is dual-core Android-powered phone by Motorola. Model Number: MB860.
28 Vragen Bekijk alle
Vraag afgerond
Earphone issue after dropping it
Hi!
I have dropped my Atrix in the floor, its glass is broken, but the worse thing is that, the internal speaker (ear speaker) is not working anymore.
I would like to know if i replace the glass, the earphone will start working again ? in case it does not, how can i repair it ?
Thanks in advance,
Márcio Coelho
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Bump!
I am in the same boat. Issues started 4 days ago. My glass isn't broken only the internal speaker (ear speaker). I am in the process of finding a screw driver to open things up.
Update
Ok - I believe I have sorted the issue. I used the tear down guide on the iFixit site (Motorola Atrix 4G Teardown) and the video on YouTube (http://www.youtube.com/watch?v=TbR56jSpl...) to open up the phone. I only had to take it to the point where you see the ribbons attach to the motherboard.
The ribbon cable that connected to the bottom end of the mother board was unattached. I tried twice to just reattached and reconnect things but found that it required a little black electical tape to hold it in place.
It is still early but the repair seems to be worked. The loose connection would make sense since the problem would come and go.
Big thanks to iFixIt for the tear down!
mdf
Was dit antwoord nuttig?
1 Opmerking:
Thank you !
I've already purchased a new touchscreen.
door
Pls, let me know if you find a solution for that.
Regards,
Marcio
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,549
