Ga door naar hoofdinhoud
Repair guides and disassembly information for Apple's 7th generation iPad. Released September 25, 2019. Model numbers: A2197, A2200, and A2198.
doesn't turn on.
it was about a year ago when it stopped charging with its original charger, i then tried mac's charger to charge it. but it also didn't work, it was charging but very slowly and suddenly went dead since then.
i send it to local repair shop and they said probably it is motherboard issue and can't be solved. can you suggest me what to do?!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I know it's a fairly common issue for the CPU to die on the 7 series and it's just not worth fixing.
You could reach out to a board repair specialist to see what they have to say. If you're out of the US, I believe iPad Rehab might be able to accept the repair. If you're in the US, both iPad Rehab and VCC Board Repairs could take a look at it. I've personally taken Rehab's board repair course and I send my data recovery jobs to Jesse at VCC. Good luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Omor Seebtaien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 98
