Green line down the center of screen
I replaced the battery, and now I have a green line down the center of the screen. Right down the middle. I'm hoping it's just the connector not seated correctly. Has anyone else seen this before?
Is dit een goede vraag?
4 opmerkingen
Did you use the isopropyl alcohol to clean the adhesive off the display and battery?
door Jacob Mehnert
I didn't need to on the screen side. It all came off surprisingly easily. I did use it on the battery side and needed to put some under the battery as the pull tabs broke off.
door mary
@mdrumhel but you did use some? Some users have reported this happening with Rubbing Alcohol.
door Jacob Mehnert
I did use some. That's interesting. Has anyone reported fixing it without needing to completely replace the screen?
door mary
