Ga door naar hoofdinhoud
Brushes making ratcheting sound, not sucking up dirt
Recently my old roomba started making intermittent high pitched sound, along with a ratchety sound. It goes all over, and is not throwing an error, but the bin is empty afterward. Took it partially apart, blew all the accumulated dirt out, cleaned it up, but no improvement. Ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
My advise is to check your seals and locate the source of the sound, my guess is if your seals get replaced that high pitched will go away, and as for the ratchety sound, make sure the dust bin is clear and take off the brush and clean everything behind it and potentially lubricate it just to be safe
Was dit antwoord nuttig?
2 opmerkingen:
Actually the rachet sound is at the 2 brushes. I can manually turn them and they make that sound. I can't tell if they are sweeping when its going on its way, or immobile. But its not sucking anything up. I feel air out the back end, so there is flow,but no aspiration.
door
Have you unscrewed the brushes and looked at the back of them? Mine were nasty.
door
Voeg je antwoord toe
kim t zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 77
