Ga door naar hoofdinhoud
The Rock Band Fender Stratocaster Wired Guitar is a guitar-shaped controller for the Rock Band video game franchise for Xbox 360.
Rock band 1 wired guitar will not turn on / connect.
I have a Xbox 360 wired Rockband 1 fender, it’s been 5ish years sense I last used it but I dug it out to play clone hero on, but when I plugged it wasn’t working, the light for the Xbox 360 logo on it would flash for a second and then shut off. I first tried a different break away cable end but I got the same result, I tried the classic wiggle the cable around to see if holding the cable in a specific way would make a better connection but I had no luck with that. I took the guitar apart and looked at the main board and there were these 2 capacitors that’s caps had turned a purplish black, all the other ones still had silver caps so I’m guessing that may be the problem?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
I have the exact same problem let me know if you solve it please and thank you
Was dit antwoord nuttig?
Did you fix it yet?
I have the exact same, but only the c52 is black. I'm gonna change it and tell you if that worked
Voeg je antwoord toe
Sleepless Gamer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 56
Altijd: 665
