Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
896 Vragen Bekijk alle
Why does my iPod keep booting into diagnostics and wont let me out?
I just replaced my screen and battery on my Ipod and now it keeps booting into diagnostics (which I did and everything is working perfectly fine) and it wont let me out of diagnostics mode.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Does it boot back into diagnostic mode after a hard reset? Hold the "menu" and center button for ~10 seconds and that should reboot the device.
If that doesn't do it, maybe let the battery die by keeping it in debug mode off of a charger, and see if recharging it gets it to boot up normally.
Was dit antwoord nuttig?
4 opmerkingen:
I tried this. It reset, then kicked me back into diagnostics. I tried with battery power, i tried with just wall power with no battery connected, i tries with firewire, nothing. just back to diagnostics.
door
@catdge You might have to restore the iPod, which will re-install the operating system and hopefully address whatever issue is causing it to boot into diagnostics. There's a decent iFixit guide on this process here: How to enter DFU mode and restore iPod
door
I will try that.
door
Just note that this will delete all data on the device, definitely the brute force option. If this doesn't do it, it's probably time to re-open the device and check for damage, missing grounds, etc... Something simple like a stuck button or disconnected cable shouldn't cause it to boot into diagnostics.
door
Voeg je antwoord toe
Catdge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 30
