My laptop is not starting
Is dit een goede vraag?
We need a little more information in order to help you. For example, what model do you have? Is there any response from the system? Backlight on the display? LED light on the CAPS lock key? Chime on startup? Does the charger make a noise when connected? First try doing an SMC reset or a NVRAM reset. If those don't work, you'll need to consider opening it up to try to diagnose the problem internally. You could try disconnecting and reconnecting the battery. Good luck!
Was dit antwoord nuttig?
HP g series pavillion laptop
OK, you should edit this post so that it has the right associated device. Right now it says "Mac Laptop Overview" which is misleading.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 29
