Screen has started displaying a green glitch after screen replacement.
After replacing the screen and testing it, everything was working correctly. Touch, cameras, brightness, etc. Once I had tested the phone, I turned it off and replaced the display cable clip, then closed the screen up. When turning the device back on, it began to display all sorts of green lines that I would describe as a glitchy screen.
Once I carefully re-opened the device, removed the clip, the screen worked as normal again.
I have replaced and removed this clip a few times now and each time the clip is in place, the screen begins to glitch.
Anyone seen or heard this before and could share any light?
Thanks for the help.
Is dit een goede vraag?
