Ga door naar hoofdinhoud
Replacing Touch Screen on Life Fitness 95X
My touchscreen broke on my Life Fitness 95X elliptical. I was able to order a replacement on AliExpress, however to install it I need to remove the old one first and reattach it to the bracket.
The old touchscreen component appears to have a strong adhesive to a metal frame. What do you suggest I use to remove the glass and then what should I use to reattach it?
This is the original screen attached to the frame :
Afbeelding
This is the replacement touchscreen, which is just the glass panel:
Afbeelding
Is dit een goede vraag?
1 Opmerking:
@jasongurwin What adhesive removers have you tried? I would start by trying Isopropyl (Rubbing) Alcohol and gently trying to pry the frame out. If that doesn't work, you can use acetone, but be careful.
door
Voeg een opmerking toe
2 Antwoorden
For first you must deattach metal frame and digitizer ,after that when you connect everything plug the MASHINE.YOU NEED SOFTWARE TO CALIBRATE NEW DIGITIZER.Also stuff from ali express sometime not working .
Dejan Čekanović
Belgrade
Serbia
Was dit antwoord nuttig?
Yes is yust a glass panel
Voeg je antwoord toe
Jason Gurwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 448
