Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
No service after a small "repair", what gives?
I put my iPhone 3G back together after removing the power button, I removed it because it was damaged and then I used led to act as a solder to keep the phone in an 'ON' position. Only problem is that now, the phone says No Service always. Did I ruin something?
Also, I have Wifi so does that mean the antenna isn't damaged?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You might have messed up the SIM card assembly, try removing the SIM card, cleaning it's contacts, and reinserting it.
Was dit antwoord nuttig?
Score 1
The WIFI antenna is in the upper part of the phone - the Cellular antenna is at the back of the dock connector assembly! They have nothing to do with each other.
I found a great tutorial on the net. Maybe it will help you!
"How I recovered my iPhone's lost GSM signal!"
http://www.mauron.net/iphonerepair/
Voeg je antwoord toe
henry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 6,824
