Ga door naar hoofdinhoud
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Vragen Bekijk alle
LCD replacement difficulty question.
Hello all,
Has anyone replaced only the LCD on one of these models, and if so how difficult is it? I can imagine they're packed quite tightly. There's no necessary destruction is there?
Also, LCDs for either A1237/A1304 are interchangeable right?
Thanks!
Is dit een goede vraag?
Score -1
1 Opmerking
I have not replaced the LCD in one of these display assemblies, but I expect it would be difficult to remove the bezel without damaging it. You have to fight your way through some very sticky double sided tape. If you have not already done so, take a look at the teardown of the MacBook Air Models A1237 and A1304. Step 21 gives a little bit of a hint as to how difficult replacing the LCD may be.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here's a video on how to do it. Judge for yourself if this is something you can handle: http://www.powerbookmedic.com/wordpress/...
Here's another one: http://www.youtube.com/watch?v=AMpzI4DMd...
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thanks, dosen't look too bad. Just the ubiquitous sticky tape. Always forget that youtube can be informative too.
Second one is for a macbook by the way.
door
I did this one, replacing not the LCD but the lid itself. I thought I was being extremely careful with the LCD Bezel, but I broke the LCD in more than one place in the process of removing the Bezel. The rest of the job was manageable, but breaking the LCD was a disappointment.
Voeg je antwoord toe
Ben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,153
