Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
iPhone does not charge past a specific battery level
I use fast charging (of course genuine from Apple, 18W), but the strange thing I noticed is that it sometimes can't charge through a certain battery level (eg 10% after 30 minutes it's still 10%), it can also sometimes charge up to a certain battery level, but will be stopped at a different battery level, namely about 70% and 90%
The only fix is ​​that I have to restart the device for it to charge up
Also added that I replaced the battery for it, also genuine from Apple
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi, you need to change the charging system and retest again to see if the phone charges beyond the said percentages.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the reply, I also changed to another fast charger and the result is still the same
About restart, or perhaps reset, I tried it too and it's still the same
I still don't understand what you mean by "change the charging system", it could be replacing lightning port or replacing charger
door
@kiyoshi1407 if the new battery is under Apple warranty, I'd recommend you take the phone back in for them to troubleshoot. It sounds like a bad battery they put in.
Score 1
2 opmerkingen:
Maybe it is, the battery is still under warranty so I will take it to an Apple center to change to another battery. I hope the lightning port isn't broken because it is expensive and very difficult to repair
door
@kiyoshi1407 It's not too awful to do, the part itself is also only around $20, the whole charging assembly is replaced.
door
Voeg je antwoord toe
Kiyoshi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 160
