Ga door naar hoofdinhoud
Audi onthulde hun gloednieuwe generatie A6-model op de North American International Auto Show van 2011 in Detroit. De nieuwe A6 heeft een conservatiever ontwerp met invloeden van de A7 en is voorzien van led-achterlichten, een geïntegreerde spoiler op het kofferdeksel, een dubbel uitlaatsysteem en optionele led-koplampen.
How do I repair my mass airflow?
Car keeps shutting off when at redlights and stop signs
Is dit een goede vraag?
Score 2
1 Opmerking
Hi @freddydilogene,
How do you know that there's a problem with the MAF or MAF sensor?
Have you checked the OBDII codes?
If so was it a P0101 or something else?
If you haven't checked the codes, I suggest that you get them checked to see what codes are there as it may be something else that is the cause and not the MAF sensor.
These are the more common problems with a faulty MAF sensor:
The engine is very hard to start or turn over.
The engine stalls shortly after starting.
The engine hesitates or drags while under load or idle.
Hesitation and jerking during acceleration.
The engine hiccups.
Excessively rich or lean idling.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Freddy,
As @jayeff has already stated, we need more information to be able to give you a diagnosis we're confident of.
If you suspect the Mass Air Flow sensor, there's an easy way to test it. Simply unplug it and drive the car. If the stalling goes away with the MAF unplugged, then yeah, it's pretty certain you need a new one. If the engine computer can't get a reading from the MAF, it defaults to preprogrammed settings that will allow the car to be driven but won't give you the optimal fuel economy and power settings achievable with a MAF. With a bad MAF those default settings will run better than the incorrect readings returned by the defective sensor.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Monique de tirage
door
@abdallahchiheb I would love to respond, but your message isn't long enough for Google Translate to be able to help me understand what you're saying. Please translate for me or indicate what your native language is.
door
Voeg je antwoord toe
Freddy Dilogene zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 112
Altijd: 7,745
