Ga door naar hoofdinhoud
How to change charger pin
How to change realme 8i charger pin full details
Is dit een goede vraag?
Score 8
4 opmerkingen
Display change
door
If you are looking for a display change, @dadibrokeit already gave you a great website to fix your phone. Here is the link for the display change incase you are unable to find it: https://www.nadiemellamagallina.com/en/m...
door
it's very simple if you have the right tools
door
Charge nahe hota h
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This may just be an artifact of auto translation, but I'm going on the assumption that you are asking how to change the USB-C charging port on your phone.
Sorry to say that iFixit doesn't have a guide for replacing that on your phone, but there's a Spanish site called Nadie Me Llama Gallina, or Nobody Calls Me Chicken, that does have just what you need. If you view it with the Chrome browser and allow it to do the translation, the guide is very much usable.
You're fortunate in that your USB-C port is mounted on a small auxiliary board mounted near the bottom of the phone and can be replaced by itself fairly easily. Here's the guide you need.
Manuals / Realme Narzo 50 (Realme 8i) / Auxiliary plate
You shouldn't have too much trouble locating a replacement part; I usually check sites like AliExpress, Amazon and eBay among others. Here's one of the first ones I found on a cursory search.
For Realme 8i Original Charging Port Board – Alexnld.com
Good luck with your repair; let us know if you need any help and be sure to tell us how it turns out for you!
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
How to change charging jack
door
Did you bother to read the previous responses where that question was already answered? Please go do so before contributing nothing to the discussion.
door
Jack change.realme 8i
door
Please RTFM.
door
If you have a similar phone that is no longer in use you can take it apart and use that particular part for the other phone .
door
Change charging pin
1 Opmerking:
I'm sorry, is there a question in there somewhere? If you are asking how to change the charging port on a Realme 8i, the answer has already been given so I don't understand why you are asking again.
door
Voeg je antwoord toe
Samiullah Ansari zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 32
Altijd: 2,801
