Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
JDM en Euro Honda Accord model CL9, in Amerika verkocht onder het merk Acura.
2015 Acura TLX need code
2015 Acura TLX 4 door sedan was running fine, driving normal running errands but went and parked for awhile but when it was time to leave it wouldnt start. Everything was locked up and it said a code is needed. Idk about a code. Please, I am afraid to drive it, I am afraid it will lock up while driving. Help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Former Honda owner here!
You might see the navigation system say something like this. Of course, there are 2 ways to fix this. The first is you can simply press and hold the (Power) button for two seconds; the system should reactivate.
Afbeelding
Now worst case that doesn't work you can get the code from accura instantly by going here: https://dev.radio-navicode.acura.com/
To get the S/N from the radio, you just press "Settings" "Info" and "back" for 3 seconds, and with the knob, scroll to detail information and setting. Then go to Unit Check and then ECU info. You can follow this video here
Was dit antwoord nuttig?
Voeg je antwoord toe
Linda Kalakau zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 517
