Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
Replaced logic board, still getting red X
Hi
I replaced the logic board, and have left it charged (not to the computer) overnight. I still get the red X but can't get it to go into disc mode by holding down the menu button (after toggling the hold). Grrr....
It's a 2007 160Gb classic. Please help! I was very excited to have replaced the logic board (first time ever repairing an electronic device!).
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Generally, I believe the red X indicates a bad harddrive. Click one of the buttons and hold the iPod up to your ear- if the harddrive is bad, you should hear some grinding and clicking.
Nice job with the replacement! It sounds like you did it correctly if it's booting.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
no grinding - hear the record player sound when holding the menu+centre but nada after that. Trying the zip lock freezer thing. I will followup on my progress
door
The red - X definitely indicates a problem with the hard drive. Before replacing a 160gb hd though (spendy$$), I would make sure all your connections are tight and connect. Disconnect and reconnect the drive to make sure all is in correct.
Score 1
Voeg je antwoord toe
kellycoleman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,166
