Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Informatie over reparatie en demontage voor de Google Pixel 7 Pro-smartphone, uitgebracht in oktober 2022. Te herkennen aan het modelnummer GP4BC en GE2AE.
After screem replacement microphone only works for calls
After replacing my screen with the iFixit one, i've notticed that my microphone only works for a phone call. Nothing else works, nor google assistant, nor the recorder nor nothing. Top mic seems to work as on the video recording it is the one that is getting the sound
Is dit een goede vraag?
Score 23
18 opmerkingen
I don't have a solution, but I do have the same issue. seems both microphones are broken for me.
door Deel
Same here!Both microphones dead after replacing the screen
door Deel
:( Same here
door Deel
I have the same issues, replace my screen now mic doesn't work except for calls and some apps.
door Deel
same problem
door Deel
13 commentaren meer tonen
Voeg een opmerking toe
23 Antwoorden
Filteren op:
Het nuttigste antwoord
OK guys. I fixed it. 100% it is a hardware issue. Basically Tomasz Góra @tomaszgora is correct. There are two tiny SMD components right underneath where people pry at the retaining bar for the screen connector. One is a 51 ohm resistor. The other is a 33pf capacitor. Both are size 0201 (very, very small). Restoring them will bring the mic 1 back. Attached pics below. The 51 ohm resistor is above the tip of the blue arrow and the 33pf capacitor is just below it. If the component comes off, it can take the pads with it. You can see missing pads in the first pic below. My soldering job isn't pretty but it works. I managed to pick up from what was left of the pads. The 2 pads in the middle between the resistor and capacitor are joined. That is where the signal comes from / goes to the other end of the 51ohm resistor. The other end of the capacitor is a ground. Hopefully this will help somebody. 100% fixed on mine. Stands to reason the parts get damaged when people pry up the retention bar to remove the screen. A nice chap called Stefan on GadgetUK Discord identified the component values.
Afbeelding
Afbeelding
Good luck
Was dit antwoord nuttig?
Score 14
3 opmerkingen:
You are missing 2 SMD components. Probably torn off whilst prying up the screen connector clamp. Se pics below. Above top of blue arrow is 51 ohm resistor. Below tip of blue arrow is 33pf capacitor. Both very small. 0201 size. If you lose one of the two middle pads then don't worry, They are joined. Pics attached of problem and fix. Soldering now the best but area is tiny and it works. 100% hardware issue. Please add a warning to the screen change guide. Good luck All. [image|3674422] [image|3674423]
door Deel
I think this is the true issue.
Thank you for pointing that out.
I don't want to risk opening it again. I'll use the "app" work around.
Thanks !
door Deel
Hi! I have the same problem but what I don't understand is that it doesn't work even when using earphones
door Deel
Hey guys for those who can't fix the mother board and finds 'Voice Recorder & Voice Memos' \ 'MyRecorder' app to drain the battery very quickly..
I created a completly open source and free app, that behaves the same but much more efficiently MicLock
I can finally use my pixel kinda normal again :)
Score 9
9 opmerkingen:
Thank you so much, I'll try it out !
door Deel
Brilliant. Great workaround.
door Deel
Hope it will work out good for you guys :)
Also if you use a phone other than google pixel 7 pro or you have any suggestions to improve let me know!
door Deel
dude ur app is sick, like I popped it on and it instantly worked!
door Deel
Wow thank you @danoren. The mic issue on my Pixel 8 has been fixed. 👍👍✌️✌️✌️😊😊
door Deel
4 commentaren meer tonen
Hi
I just fixed it.
1 Download voice recorder & voice memos
That’s it everything start working on another third apps. But you cannot delete the ap
Score 5
7 opmerkingen:
I just tested this on my phone. Did not work. Did not correct the problem in any way.
door Deel
Both of this apps work, but the one with the back logo you have to start a record in the music option.
So
1 your start a recording
2 stop the recording
And the send any voice message in WhatsApp.
That worked form me.
It seems to activate the other 2 mics (top and camera lens)
door Deel
Yes it works, but this is bull $@$*!!
We spend so much money on what's suppose to be a top of the line phone.
Google, this may be my LAST Pixel phone!!!
BTW folks, it "MyRecorder" app from the play store that "fires" things up for me.
The sock "Recorder" app does NOT"
door Deel
This helped me!
It somehow makes all the other apps use mic 2/3 (like in phone calls and video recording). The app is "Voice Recorder & Voice Memos" by Dairy Apps & Notes... "MyRecorder" is another way to find it.
Thank you whoever you are, you made Assistant useful again.
door Deel
This is absolutely insane, but this does seem to have worked. Install the app, run it once, and mics work again. 🤷🤷 Mine was not working because of a screen replacement.
door Deel
2 commentaren meer tonen
Nah, it a garbage device. I won't be buying another. Honestly will probably will go back to Samsung. It would be easy if we could look and see where the microphone is.
As a workaround, I can use speaker phone and yell into the speaker. That seems to work... But nothing else works.
Score 4
Hi everyone,
I recently replaced the screen on my Pixel 7 Pro, and after reassembly, the bottom microphone stopped working. While inspecting the motherboard under a microscope, I noticed that a small component near the screen connector might have been damaged during reinstallation.
It’s possible that this component is part of the microphone circuit, which could explain the issue. Has anyone experienced something similar? Could someone help identify the component and confirm whether it’s related to the microphone function?
Any help would be greatly appreciated!
Afbeelding
Thanks!
Score 4
3 opmerkingen:
Could you please enter the pixel test menu and test all 3 microphones and see if there is any other microphone that is problematic? (Enter the code *#*#7287#*#* in the phone app)
Mic1 is the lower microphone
Mic2 is the camera microphone
Mic3 is the earpiece microphone
door Deel
The lower microphone is not working on my phone.
door Deel
@tomaszgora Did you ever get this fixed? I have the EXACT same problem on my Pixel 7 Pro...missing one of those components! Does anyone know what the types and values of those 2 components are in the photo?
door Deel
I really don't have the time to pursue this to the next level. But I might just make the time. This is ridiculous that Google is not helping with this problem.
Score 3
7 opmerkingen:
After months of dealing with this issue, still no help from Google or their staff. No microphone replacement parts available. It is the strangest problem I've ever encountered with technology. I meticulously replaced the screen as instructed the first time. Flashed my fingerprint scanner (instructions not provided) and then tested the phone. That's when I noticed the microphone issue. No previous issues with the mic until this screen replacement. So what do I do? Order another adhesive and open the phone back up. Nothing was out of place, bent, or broken. But my mic is still not working correctly. The mic seems to work on phone calls, but I've been told that sometimes it sounds like I'm underwater. This happens about a 50% of the time. With any other app or feature the mic is completely non-functional. TTS no longer works, Google assistant no longer works. My theory is this: its got to be a software issue. Maybe the flashing affected something? Why else would it work perfect (sometimes) when on the phone?
door Deel
I've tried every fix I can find. Nothing helped. I kind of wish I had just lived with the dead pixel vs dealing with a broken mic. I really like Google phones. But I'm not so sure if I'll buy another. The fact that no one from their team has even reached out to try to fix this is disappointing to say the least...
door Deel
Same problem here. Had the screen replaced, but the fingerprint sensor wasn't working. So I used the workaround to flash the fingerprint sensor firmware, and it works since then, but one of the three mics is now out of order, and the update to Android 15 didn't change anything. It's definitely a firmware problem. But there are no solutions available to my knowledge. It's the main mic (lower edge) that is out of order; phone calls use the upper mic, too, but you sound washed out as it's far away from your mouth usually. All applications that rely on the lower mic solely (voice messages, Assistant...) don't work.
door Deel
Before flashing the fingerprint scanner fix - did all microphones work?
That's the question we need answering...
door Deel
I have the same problem. When my screen broke I replaced it with a cheaper non official one (around 100 bucks). I had this problem there but I thought it’s because it’s unofficial. I replaced it then with an official one from ifixit but nothing changed. It’s a software problem. Like John, it happens to me like 50% of the calls. A new idea is maybe the ANC’s fault. I saw at the specs it has active noise cancellation and a few times I’ve been told by my callers that they hear perfectly the background noises but they can’t hear me clearly, so I thought the ANC tries to block the wrong sounds. Is there a way to disable anc?
door Deel
HI All,
It is hardware issue. please read this and run the test. It will show what is the problem.
Your Google Pixel has a secret diagnostics menu — how to find it
Score 2
1 Opmerking:
It doesn't make any sense to be a hardware issue. Changing a screen doesn't interfere with the position of the bottom microphone ...
door Deel
Afbeelding
Afbeelding
Score 2
I faced the same issue after display replacement and it seems like the 51 ohm resistor near the display clamp is missing, probably because I was harsh when pried out the clamp. I left it for diagnosis and possibly repair to a technician, will update after result.
Afbeelding
Score 2
Maybe it's when we updated the fingerprint sensor with win10 drivers ?
Score 1
1 Opmerking:
The problem is on the bottom mic. No voice typing, no voice recording but how in the world they can hear my voice at the other side?... Or maybe I'm going crazy 😱😂
door Deel
It is definitely a software/firmware issue somewhere in the phone but I can't tell you what apps are causing the problem or what apps are unrelated. I have had this same issue since I replaced my screen with the iFixIt replacement and flashed my fingerprint scanner. So that works now, but even with these issues, I definitely do have some apps that are still working fine with the lower mic, which suggests that it is an issue with specific apps not commingling with each other or their settings/default settings/firmware/software updates are not addressing the issue or not installed/setup correctly.
For me, most (but not all) of my issues involve the pre-installed (integrated) software and/or features along with all of the Google run apps I currently have installed that call for a microphone.
Apps and features including the likes of the Recorder, Google Assistant, GBoard, or the Now Playing feature are definitely not responding to my voice, yet some apps like phone work fine.
I have tried every recommended option here (other than a factory reset) without any success. I hope there is a solution or work around shared soon, because I am not looking forward to having to hit the Reset button.
Hope I was able to give some insight that may lead to a solution and not just the same information regurgitated from the top.
Score 1
3 opmerkingen:
I also agree that it must be a software issue. Ive been inside this phone several times and there's no indication that the lower mic would be affected from a screen replacement. My question is this: has anyone tried the dreaded factory reset option? Personally I have not. Wondering if anyone here has before I consider testing it.
door Deel
By any chance, did you try reflashing stock Android?
door Deel
So I had the same issue after screen replacement, for weeks nothing worked. Miraculously after a software update it started working. My conclusion is that it's a software problem most likely caused by the flashing of the fingerprint. I had tried all the other "fixes" and nothing worked.
Score 1
3 opmerkingen:
Which update? Did you try to reflash the whole OS before this happened?
door Deel
Later Update (03.12.2024) - reflashed to latest factory image / fully wiped everything - still not working :(
door Deel
It’s been like several months I replaced the screen but I didn’t flash the fingerprint. Boredom I guess, I used a code to unlock the phone. I flashed it last month, nothing changed with the mic, the problem remains the same
door Deel
@lucianobuszmicz This seems to be a common issue with the Pixel 7. I've linked a thread here that you may find helpful. Someone suggests cleaning out the microphone hole with first a vacuum then blowing air into it. It is possible that during the screen replacement process, some finger dirt or perhaps adhesive from the screen got into the microphone.
7 opmerkingen:
Hi @dannish,
Wouldn't a blocked microphone hole also prevent the microphone from working properly on calls?
The OP says it does work but only on calls, nothing else. Presumably they're not using the phone in speaker mode on calls when saying this
door Deel
@jayeff That's what I thought until I read the thread, apparently certain software on that phone uses both top and bottom mics, some only use 1. So those which rely on 1 mic will be completely unusable, but those which use both still work. It's odd but the solution on there seems popular.
I've experienced OCA getting into a speaker and dulling the sound quite significantly during a phone screen repair myself so it could be possible for mics as well. Mic holes are even smaller than earpiece speaker holes so that could just be it.
door Deel
@dannish
Fair enough.
Cheers
door Deel
I tried this fix but still no luck. It would appear after replacing my screen with an Ifixit OEM screen, my bottom mic no longer works. I was quite careful during the replacement. Is it possible I broke something internally? Everything else seems to function normally except the bottom mic.
door Deel
@johnjanis
Same here.. si frustating.. juste waiting to see if the next software update will fix it
door Deel
Has anyone had any luck with this problem? My mic stopped working after screen replacement. They had to flash the fingerprint scanner to make it work again. The bottom mic doesn't work for phone calls
Had the same problem with microphone after replacing the screen myself, everything else worked flawlessly. Tried everything, no software solution will work, it is a hardware issue. Sent it to google and they replaced the motherboard and sent it back to me. Somehow they did not realize the screen had been replaced so they didn't charge me anything.
2 opmerkingen:
How long had you owned the phone? I believe they only cover the phone for one year after purchasing but I could be wrong. I remember looking into that a while back but no luck.
door Deel
Witch one exactly? Because it doesen't work!
4 opmerkingen:
The recorder app that works for me:
https://play.google.com/store/apps/detai...
It's working only as temporary fix.
door Deel
Even with the Factory reset...IT dosen't work...change 3 Times the screen ( ifixit send me these replacement), and dit mot work...
door Deel
The app technically works for me but it actually doesn't "fix" the bottom mic. The app basically overrides 2 of the mics (top and bottom) to actively listen. So in actuality the bottom mic is still "broken"
door Deel
1 Opmerking:
I wonder if it's related to Android 14. It would mean that installing an older Android version could make it work again? Let's test that theory
door Deel
It sounds like the bottom microphone might not be functioning properly after the screen replacement. Here are a few things to check:
1. Check for Obstructions – Make sure there’s no dust, debris, or adhesive (like from a screen gasket or epoxy) blocking the bottom microphone hole.
2. Inspect the Microphone Flex Cable – The Pixel 7 Pro’s bottom mic is part of a flex cable that could have been accidentally disconnected, damaged, or not seated properly during the repair. Try reseating the connector.
3. Test in Safe Mode – Booting into Safe Mode can rule out any software issues. If it works in Safe Mode, a third-party app might be interfering.
4. Check Sound Settings – Go to Settings > Sound & Vibration > Microphone to see if there’s anything unusual.
5. Try a Factory Reset – If the issue is software-related, a reset could fix it. Just make sure to back up data first.
6. Replace the Mic – If none of the above works, the microphone itself may be damaged and might need replacement.
Ok. What worked for me
Contacted Google, told them about my issue - that a mic isn't working anymore and they arranged a replacement with a refurbished unit - at no cost for me.
The decide was out of warranty.
Please try that. Do NOT mention replacing the screen on your own.
1 Opmerking:
Unfortunately, the Pixel 7 Pro was never officially available in Poland, so I’d have to go through an external warranty service—which isn’t always the most cooperative option. :)
door Deel
I already sold my old phone, but just to add this here: I had the screen replaced, and needed to update the fingerprint sensor with a workaround flashing the firmware, but then the main mic stopped working. Nothing helped until I made a factory reset before selling it; after that, it worked again in all tests. Definitely a firmware conflict in my case.
I am facing the same issue and I can confirm what PlanC said. I opened the phone again and the resistor is gone. This was a very bad engineering choice from Google, as removing that bracket requires force to be applied in a way that is VERY likely to tear off these components. I do not think I will bother repairing this, as I have already spent enough fixing this now 3 years old phone. Maybe I'll find a cheap, half broken Pixel 7 Pro and swap the motherboards.
2 opmerkingen:
An app fixed the problem: microphone speaker yellow color background
door Deel
I've developed a fix as a personal project for my phone (kinda mimicing the speaker app, but much easier to use and battery efficient).
it's completly free, open source and safe, works localy on device.
you can check it here if you want: https://github.com/Dan8Oren/MicLock
door Deel
the fpc connector socket is damaged, some missed
@planc51628 You provided the correct resistor and capacitor values ​​for this issue.
Is there any chance you know the capacitance and resistance of the other components on this board? I'm referring to the components next to the CS35L41B, marked in the image as 1, 2, 3, 4, and 5. I blew those components out with hot air during CS35L41B replacement
Afbeelding
All components are located under shield marked on photo below
Afbeelding
best regards
Voeg je antwoord toe
Luciano Buszmicz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 196
Altijd: 8,038
