Hoverboard not turning on
Have green lights on charger till I plug into hoverboard and lights go out can anyone help me π
Is dit een goede vraag?
Could be the battery. If you donβt charge it very often then the battery can lose charge and if it drops below 30 volts the bms wonβt accept a charge. Will probably need a new battery. Open it up and check the battery voltage with a multimeter.
Was dit antwoord nuttig?
Battery capacity is 25.2v, tested capacity is 24.7
You need a new battery as it's gone below voltage I'm afraid.
Thanks for that, will look for new battery π€π
Do you know best place to get one from???
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 53
Altijd: 288
