Ga door naar hoofdinhoud
A Vornado circulator uses special airflow called Vortex Action to circulate all the air in the room. The air flows fast, cool and constant to create a cooling experience unlike any other.
3 Vragen Bekijk alle
How to clean accumulated dirt from the blades and interior
I need to figure out how to remove the front grill so I can clean accumulated pet hair/dust off blades and interior. It's so gross I will have to replace if I can't figure out how to clean Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
There are three screws on the back of the fan. Remove those screws and you should be able to take the fan grill off. Once you get the grill off, clean it with water and a mild soap. Make sure the fan is unplugged while you clean it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sarah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 916
