Ga door naar hoofdinhoud
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
64 Vragen Bekijk alle
Replacing Magsafe "T" connector with an "L" connector
Hi,
I have a Magsafe 85W with a broken T connector, and I have a Magsafe 85W with an L connector but a failing power supply.
So I want to replace the broken T connector with my other L connector.
It would be ok to join both cables in the same order, the inner cable of the T power supply, with the inner cable from the L connector, and the outside cable with the outside cable from the L connector?
Thank you!
Esteban
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sure. I interchange them all the time.
Was dit antwoord nuttig?
Score 5
1 Opmerking:
Thank you for answering, it's working perfect.
door
Like the previous answer. Connect the inner cables together and the outer cables together. I just did it and it works perfectly.
Voeg je antwoord toe
Esteban Eid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 8,971
